I had a problem with my automix crashing after making a song list. Someone said it was a problem outside of VDJ, posibly a .dll. I have updated the mappers for the Hercules controller and the DMC2. I ran it one time and no crashes. I think this fixed the problem.
My question is... How do you read the Crash guard report ? Can you explain what this means so we can decipher the problems?
Example:
Crash ID=05dd152c (date=712092140, version=5.0 rev.6, build=506, thread=Main, dump=c74024ff, excode=c0000005 (1,7c9140df))
Example:
geposted Wed 12 Dec 07 @ 8:47 am
its used by the dev team mostly. However I did ask about your crash and was told it was a plugin or external library causing the fault.
geposted Wed 12 Dec 07 @ 8:56 am
Good to know they will use the crash guard report to pinpoint the problem. I think my problem was the outdated mapper used in conjunction with 5.4 version and 5.6 of VDJ. I have made all the updates, and I think this will fix the problem.
geposted Wed 12 Dec 07 @ 10:23 am
Billy,
I was goin to say something like that, as it might be a external source, that was doin you, glad you are sorted now mate :)
Jimmy b
geposted Wed 12 Dec 07 @ 11:32 am
Delete that crashguard text now that the teamers have seen it, makes it easier in the future so you dont have a ton of crashguards for the team to search through:)
geposted Thu 13 Dec 07 @ 1:11 am
