Forum: VirtualDJ Skins
Topic: I'm in clipmask hell....
I'm having some really frustrating issues with a skin. I have some buttons that fall inside the clipmask for the platter. Is there anyway to have the platter spin and make the buttons operate?
geposted Wed 12 Dec 07 @ 6:04 pm
Clipmask "can" overlap with buttons, but when the platter image will be spinning, everything that is over this clipmask will start flickering (blinking) - rendering issue. I suggest you avoid overlapping the elements.
It depends on your design but the clipmask has to be identical to the area you want covered. So if there are buttons inside deck that you dont want masked you will have to cut out the area where your buttons are.
