So I decided to purchase the pro edition after using the trial(I love it). My only question is, when I install the Cue 5.0 Pro,what will happen to my database? I've scanned all my files and adjusted the BPM and wave form for alot of the hip/hop and really don't want o go thru all that work again. How do I convert my Virtual DJ Trial database over to CUE 5.0 Pro? Will the install program automattically recognize the file??? Please help!
geposted Thu 13 Dec 07 @ 4:17 am
Your database should be safe and sound on the music drive.
Navigate to the drive where the music is loaded and you should find an xml file.
This stays with the drive and is what the program will load up when it starts regardless of version.
For virtualdj is should look like this "VirtualDJ Local Database v5"
If you load Cue, I would imagine you would need to change the tag to read "NumarkCue Local Database v5" or "Cue Local Database v5" and it would properly load up.
Maybe a Cue user could chime in with the actual tag name.
geposted Thu 13 Dec 07 @ 4:59 am
That used to a problem, I hated updates because of that.
Now its all been taken care of, exellent job people!
geposted Thu 13 Dec 07 @ 7:28 am
Bought VDJ Pro instead...............everything transferred great!!!
Thanx for all the help
DJ Extreme
DJ Extreme
geposted Tue 18 Dec 07 @ 7:31 pm
