You have helped before on this situation and I thought i had made things better. After loading virtual dj , and loading my first two songs... I can let it set there and without even playing, without two songs necessarily loaded into players... my cpu usage (Virtual DJ only) runs from 7 percent to 50% , then it will spiike to 90+% and lock up.
I then have to scramble and use my back up cd player , and allow myself a chance to reboot computer and then restart VDJ. It then seems to run fine (although) I have had to do this as many as three times. I don't see what is causing this. I really enjoy the program as do others I have recommended.
any further thoughts.
PS how can i go back and find my previous threads/ questions?
thanks for all your help and support . Michael aka dj Trex (played Disco Duck when it was new) haha
geposted Sun 16 Dec 07 @ 12:27 pm
Michael what are your browser settings, I believe it is lookin for tags and cover art, set tose accordingly. I use for the database Add Manually, I disable the search for cover art.
geposted Sun 16 Dec 07 @ 5:17 pm
that is a good thought but I'm currently using version 4.3... It was cruch time, I started to get the upgrade but was a bit scared due to the forum... keeping my cues and playlist. Would your question apply to version 4.3 as well? thanks michael
geposted Sun 16 Dec 07 @ 6:13 pm
No my question was based on 5.0 and above. I believe there is something else going on in the background that could be doing this, if not I appologize. Check for wifi and stuff like that or even anti virus.
geposted Mon 17 Dec 07 @ 1:04 am
what is your power settings? is your lappie sleeping at all, is screensaver off, battery settings, shutting down harddrives after 2 mins or something?
open the task manager and sort by cpu usage, see what process is eating up your cpu
geposted Mon 17 Dec 07 @ 9:31 am
Thanks for all the suggestions.
I disable wifi , and anti virus before booting VDJ.
Power settings are Never sleep, never hibernate etc.
I have removed the global database and the search for new updates.
I disabled browswer settings for "always search for new pages" etc.
also removed temp files , cookies... not that any of this will help ... but once it was searching for updates.
Your suggestion about sorting as to cpu usage is helpful .
Thanks again... You guys are the reason i purchased the program... for assistance.
PS, in next version ... give us an option for small , medium , Large font.
hard to see in the dark haha. sincerely Michael AKA older than dirt. haha
geposted Mon 17 Dec 07 @ 2:00 pm
