Can you take a beat and take out the voice?
If so, can I do this on the beginner software, or the 300$ version?
geposted Mon 17 Dec 07 @ 1:09 pm
the vocals+ effect does this, not sure if its home version (never used it myself). it does an okay job, but ive worked in studios and vocal stripping is quite alot of black magic to do a good job and cannot be done properly with just a plugin. but try it out, its useful if you're going to mix over it. it doesnt strip both vocal and beat though, this is a multi-stage process since all it does is drop certain frequency ranges
geposted Mon 17 Dec 07 @ 10:21 pm
