I was using a 14.1 inch laptop before, but now I bought a new one that is a 15.4 inch display. Is there a way to maximize Virtual DJ so that it fills the whole screen? I can hit the maximize button, but it just does not look right. Is there some kind of setting that I am missing here?
DJ Jimmy J
DJ Jimmy J
geposted Tue 18 Dec 07 @ 3:21 pm
Anyone????
geposted Tue 18 Dec 07 @ 5:22 pm
Did you try the skin re-sizer Jimmy??...Also look and see if the skin you like is available in the resolution you need.
geposted Tue 18 Dec 07 @ 6:10 pm
I never heard of re-sizer, what is it and where is it. I am using the normal internal mixer skin that somes with the program. Where would I find skins in my reesolution?
geposted Tue 18 Dec 07 @ 9:10 pm
geposted Tue 18 Dec 07 @ 9:13 pm
Can anyone get the resizer for me, it wont download.
geposted Tue 18 Dec 07 @ 9:53 pm
I think Jim you need to look at skins with sizes 1280x800, my screen on my lappy is the same as yours.
I use Cioce's Que skin v1.5 ( which is a good skin I may add ) and that is 1280x800 and it fit's my screen spot on. Give it a try.
And I could be wrong.
Jimmy b
Jimmy b
geposted Tue 18 Dec 07 @ 9:59 pm
You can also set your main screen resolution to 1280X768 and get a skin that is 1280X768. This is what I use.
geposted Tue 18 Dec 07 @ 11:19 pm
