Hi,
I use my own MIDI controller which is working fine with VDJ. The only pb is the following: there is a latency when i quickly modify the EQ of a track when the track is playing.
- It does not come from my controller (it works fine with volumes)
- It may be the setup of the shortcut: mine is: equalizers->bass-> temporary : untick | value=0
-Mayeb VDJ has a latency for calculating the audio output from EQs modifications. But it seems that there is less latency when the movement is a bit slower. It looks like a "inertia" function has been implemented... Am I right ?
Thanks for helping me out on this. It is a bit tricky during my sets.
Please also let me know if you have this pb with other controllers.
Thanks for this great piece of code :)
Gilles
Gilles
geposted Fri 19 Nov 04 @ 6:44 pm
If you are a XP-10 or DJ-Console user, please let me know if you experience the same problems
geposted Sun 21 Nov 04 @ 2:53 pm
hi
not sure why you have this problem.
I have a DJ console, and I dont have latency problems with the EQ knobs, even when moving them fast.
Anyone got an idea?
Anyone got an idea?
geposted Mon 22 Nov 04 @ 12:34 pm
thanks for your input. I think the EQs MIDI control is not setup properly on my side or on VDJ's.
geposted Mon 22 Nov 04 @ 8:34 pm
try different settings in your midi mapper...
maybe there is something wrong with the values
geposted Tue 23 Nov 04 @ 12:37 pm
