Here's the backdrop to my question.
i have been using virtaul dj4 now 4 about a year with xp. got me a brand new vostro 1700 with vista, so up i went with vdj 5, and run into the rezipping problem.
i brought the songverter and converted all my regular playlist zips. The zips play fine in vdj 5.
the problems comes when i add the zips to the search data base, i can only see a mp3 file in the search results. so i'm only getting music and no lyrics.
I have a playlist folder that is sub-devided, that again worked perfect with vdj 4.
now with vdj 5, if i search a sub folder, i see the karaoke file, but the i search the main playlist folder, i'm only getting the mp3.
Could someone help me 2 where i going wrong, and how i can get that problem corrected.
i've searched the furums with little help and tried bit a pieces of adjustments to no avail.
Even put all the songs in one folder, n got the same result. i'm all out of ideas and need some help with this one.
thanks for ur support in advance
geposted Wed 19 Dec 07 @ 2:33 pm
hey, i posted 2 fast just had 2 read a bit more.
found the answer here in this tread.
http://www.virtualdj.com/forums/76865/General_Discussion/5_0_Rev_2_Karaoke_problem_persists.html?highlight=karaoke
worked pretty ok
worked pretty ok
geposted Thu 27 Dec 07 @ 5:59 am
