Hello
I was wondering where I could get that common used scratch samples.The "fresh" sample, "ahhhhh" , "aa yeah" or "1 2 3 4".
I have tried to look for them in p2p programs but they aren't playing.
Anyone.....
Anyone.....
geposted Thu 20 Dec 07 @ 7:04 am
Well, you can buy them , search for 'breaks' on dj music vendor sites, though u'd much easily find vinyl than mp3 files bro. Alternatively you can do like me and use vdj to sample them from the actual songs they came from....... i.e the aaah- there's one at the beginning of the freak out song, then the fresh sound - there's one on a fedde le grande song( will check 4 ya which 1 specifically) and the aah yeah - eery body knows thats from Run DMC....hope that helps, its actually fun once you get the hang of it! Oh forgot to tell you to look at the downloads section on this site, there's some good ones!
geposted Thu 20 Dec 07 @ 5:45 pm
Beatport.com's Hip-Hop Tools.
Go to the Hip-Hop section, and I'm pretty sure there are some breaks in the Top 10 Purchased tracks.
geposted Fri 21 Dec 07 @ 7:02 am
sampleswap.org has lots of samples for no charge but im not sure if they have the exact stuff you are looking for
geposted Tue 26 Feb 08 @ 12:06 pm
