When I record the setting it saves the .wav's on is 1,141kps ?? the files are way to huge to do anything with. One song is like 100mb's ? How do I change this ??
That is of course talking about the normal record setting in Virtual DJ and not using anything else.
I have no idea why it saves this large and can't find the pace to change it.
If i can't do anything can anyone reccomend a good compressing program ?
geposted Fri 19 Nov 04 @ 11:46 pm
Try to record your song in MP3 format:
1. Less space (Much less)
2. Sometimes when you record your mix in Wav format, you might have some "skipping" in this record..
geposted Sat 20 Nov 04 @ 5:51 pm
