Hello,
Some karaokesongs are with a singer that sings for the whole song.
Is it ment to be that people must sing harder when they want to karaoke or can you filter the singer away?
geposted Sat 22 Dec 07 @ 4:21 am
What you are observing I believe is multiplexed karaoke songs, the regular karaoke songs have NO VOCALS at all.
geposted Sat 22 Dec 07 @ 12:54 pm
Ok thanks bryantpb,
Normally I work with vids, also for karaoke.
Now discovered CDG.
Now discovered CDG.
geposted Sat 22 Dec 07 @ 1:19 pm
Can VDJ remove the vocal from multiplex, or is there a plugin, or does anyone know of software that will do it so I can use the files on VDJ. The file I use are DAT, MPG & AVI.
geposted Tue 26 Feb 08 @ 4:23 am
You can remove most of the vocals using the sound effect "vocals+" in your effects browser. But it reduces the quality of the song big time. There is no software out there that I have tried that will remove the vocals and leave the song sounding like it is supposed to.
Tim Breckheimer
Phoenix, NY
Tim Breckheimer
Phoenix, NY
geposted Tue 26 Feb 08 @ 10:11 am
Hi try this if u using the .dat file for karaoke
http://www.virtualdj.com/addons/view.html?type=sound%20effect&page=3
Download the 6th one down the page>> by Deun Deun (Balance stereo/mono)
U could change the right/left audio mono it or stereo. In the way if ur .dat karaoke file only have the right channel with voices, u could elimate that totally playing mono in ur left channel or vice versa. I have use it B4 and it werk. Give it a try;)
regards.
regards.
geposted Tue 26 Feb 08 @ 12:50 pm
Sunfly has a series that contain the song with vocals on the left channel and the instrumental (with backing vocals) on the right channel. If the singer is not that good you could mix in the vocals from the left channel ;-).
Ewout
Ewout
geposted Tue 26 Feb 08 @ 12:51 pm
If the multiplexed disks are of the series called "original footage" or similar, they tend to be VCD style files as opposed to CD&G (as they carry video footage too) these can be ripped using dvd decrypter and setting "stream processing" to whichever of the two audio streams you want. They are a lot like a multi language dvd in that there are mutiple audio tracks, one with vocals and music and one with just music.
For CD&G multiplexed disks it gets a lot more complicated, however there's info here that may help :-
http://www.pcdj.co.uk/forums/showthread.php?t=140
geposted Tue 26 Feb 08 @ 9:19 pm
Thanks spinnaj. Just what I wanted!
you wrote....
regards.
you wrote....
regards.
geposted Wed 27 Feb 08 @ 12:52 am
np chris, njoy...
geposted Wed 27 Feb 08 @ 2:39 am
