what do you think of this idea before I post it on the New features forum ?
IDEA: add a back mute to the scratch. that is, when you roll the wheel backwards, VDJ Mutes the sound. it would be like emulating the crossfader and would allow djs to scratch without having a real mixer hooked up. obviously this would be an option and not on all the time for those who want to do baby scratches need both directions
WirelessDJ
WirelessDJ
geposted Sat 20 Nov 04 @ 1:30 pm
lol louis
get with the times bro this was added to the last version of VDJ...
http://www.virtualdj.com/forum/display.html?topic=7230
geposted Sat 20 Nov 04 @ 1:31 pm
I'm am talking about a check box in config for those who are programming challanged like myself.
Is there a DLL I can pop in the FX folder?
geposted Sat 20 Nov 04 @ 1:42 pm
Just enable the scratch plug-in in v2.05 - there's also a skin that has an autoscratch on/off button (or it can be assigned to a keyboard shortcut)
geposted Sat 20 Nov 04 @ 1:43 pm
Yes, the checkbox you're looking for is on the "plugin" page in the config (well actually it's not a checkbox but a dropdown, I hope you'll be ok though). ;)
geposted Sat 20 Nov 04 @ 1:44 pm
all you have to do is goto the plugins page of config and select which scratch effect you want for each deck...
I don't see it? will it work with the DAC-2, HDC and Xp10?
geposted Sat 20 Nov 04 @ 1:45 pm
Oh I see it now! can you change the spelling already? DECK! not DESK
hehe thanks
hehe thanks
I think what we really need, especially with the XP10 is a fade assist. I have seen DJs scratching and 99% of the time the crossfader is in sync with the scratch. Muting the sound does not really help that much. I mean fading to the other deck as you scratch.
geposted Sun 21 Nov 04 @ 1:56 am
how does that work?
geposted Sun 21 Nov 04 @ 2:56 pm
Have a look on the macourteau's guide:
Clax
Clax
geposted Tue 23 Nov 04 @ 8:18 pm
