Was up everyone? I just bought the Numark Total Control and I must say its worth the money I used it at a gig in a club lastnight and it worked smoothly. Only down fall I find is that the Jog Wheels are a bit sensitve my headphone cable which is a very light cable touch the wheel and also when the bass kicks in it affects the Jog Wheel gets affected maybe it was due to where the console was located. but i will keep you all updated on it but it works good and a few other downfalls are that u cant record using Cue LE nor broadcast, and u dont have the hot keys that you can use on ur laptop I find that was good for quick use of samples.
geposted Sat 22 Dec 07 @ 4:10 pm
for the full features of Cue you need to purcase the full version or VDJ
as the LE software was a gift to get you started ,
glad to hear you like the total control i will be getting one my self shortly :)
geposted Sat 22 Dec 07 @ 5:21 pm
my 2 cents.... i love the TC...kant even think of djing without it..lol....
djreaper
geposted Sat 22 Dec 07 @ 5:31 pm
I concur!...FULLY!!!
The Total Control is turning out to be one of the best decisions I ever made. I was afraid it would be a tinker toy but it actually works great and is pretty well built. The only things I have a problem with is the cue button being so close to the crossfader and it is VERY easy to nudge the jog dials. It is ok now though it just took a bit to change the way I crab.
Get off ME! I know what you are going to say before you say it and YES...the toys are mine! At least when my little girl lets me play with it.
I also use the X-Session Pro for extended shortcuts as well as video fader. Guys if you don't already have one you should grab one even if just for fun. $75-$80 at G.C. and you are good to go.
I bought The Total Control one day and had it shipped overnight. That night after I order the TC I bought and downloaded VDJ. Best decision ever. Cue LE is ok to play with but going with VDJ full you are much better off. I know the $300 can seem steep at first but after you just do it you will not even think about the price.
geposted Sat 22 Dec 07 @ 10:52 pm
