hey all... new to virtual dj. hi to all.
think its about time to go digital and virtual dj seems to be the way to go.
quick question about the x10 controller...
ive read that i can use just one controller. use the switch button to change between players.
but since the x10 has only one 'twin phono' out-put...... how does that work with the 2 players on the software.? (2 monos??)
do i have to use the x10's output soundcard or can i just use it to control the players and use my laptops external soundcard (which has 2 full sterio outputs...)?
cheers...
cheers...
geposted Sat 20 Nov 04 @ 1:48 pm
where can i find the lame_enc.dll to record in mp3
geposted Sun 21 Nov 04 @ 2:55 pm
@ payner:
Yes you can use external soundcards (read more under tab "products > hardware > XP10".
https://virtualdj.com/products/xp10/
@ waynenrich: google is your friend ;)
http://www.webhostxpress.net/~mitiok/lame-3.96.1.zip
erXon
erXon
geposted Sun 21 Nov 04 @ 4:10 pm
Lame: http://www.mp3dev.org/
geposted Mon 22 Nov 04 @ 6:25 am
