I've been running a VirtualDJ rig for several months using a decently specked computer and it's been alright, except that when loading tracks (expecially large videos that take some time to load), and maybe doing some heavy scratching or effects, I get some subtly glitchy audio output. Lately it seems that it's been getting worse - like enough that you can almost see that other people in the club are noticing it. Normally I'd only notice it myself listening on headphones or whatever.
Anyways, a while back I thought a better soundcard might help, so I upgraded my M-Audio Firewire Audiophile to a MOTU Ultralite. Mostly I love the card - I can crank the quality settings up and it sounds okay - but still get that glitchiness... reducing all the quality settings all the way don't help a bit. I must have tried a zillion things to fix this - but one substantial thing remains - ditch Vista and install XP.
I've heard of others who say that using XP tends to correct these kinds of audio problems. Anyone else out there with this experience who'd like to share?
geposted Mon 24 Dec 07 @ 1:07 am
What are your performance settings?? I would try Safe mode, if it is checked uncheck it also the same with Overclock. I had almost this same issue and the Safe mode HAD to be unchecked where as on a different setup it had to be checked.
Another thing is to go to your device manager and right click on the soundcard, properties, find your audio device, properties again and put a checkmark on Do Not Map Through This Device.
Also go to each of your harddrives properties and uncheck Allow Disc Indexing
geposted Mon 24 Dec 07 @ 1:09 am
I've tried all those things and none of it seems to make any difference.
The only thing I haven't tried is the hard drive properties - where do you do that? Device Manager?
I don't think that'd really fix the problem, but it might eliminate certain scenarios where it would get bad. I do think it could have something to do with a conflict between the disk controller drivers and something else though...
geposted Mon 24 Dec 07 @ 2:43 pm
I'm having the same issue where I hear small glitches here and there with Vista and a maya44 usb. Coming from an XP laptop there were no issues whatsoever.
I've disabled all other devices, killed off any processes that could possibly interfere - still have it happen occasionally. Like the post above says though - just small sound glitches and not very noticable... but still a pain. Have also tried all possible VDJ settings with no luck. Was thinking that it was the soundcard - but have heard that others use it with Vista no problems.
Just bugging me - if any ideas on what to try next please post.
Cheers.
Cheers.
geposted Fri 14 Mar 08 @ 12:56 pm
