Hey everyone. Does anybocy know why I get "protection error %i" When I attempt to run VDJ from a different windows profile? VDJ will not run.
geposted Mon 24 Dec 07 @ 3:25 pm
contact support
geposted Mon 24 Dec 07 @ 3:36 pm
if you password protect your username it encripts your documents folder wich contains alot of your effects loops samples database ETC.
support could help you trouble shoot the issue if that is the case.
otherwise eliminate your login password on your windows login and allow your documents to be accessed
by other user accounts on your computer.
typical windows NTFS encription system.
if you really need to password protect your computer use a BIOS password
geposted Mon 24 Dec 07 @ 3:45 pm
protection error usualy means you have inadvertently engaged the antipiracy protection
best to make a ticket too
geposted Mon 24 Dec 07 @ 4:04 pm
