I would like to change sound effect controls to control the video effects or video transitions on my Numark Total controller.
I us the Fkeys for controlling the sound effects, unfortunately no one has made a mapper yet for the NTC.
Is there a way I can make this happen without a mapper?
geposted Wed 26 Dec 07 @ 4:29 pm
you could map the console manualy :) via the midi mapping section on
remote controls > midi
geposted Wed 26 Dec 07 @ 4:34 pm
That would be great. Could you please give me the detail instructions on this? I heard of this but just to computer illiterate to figure it out.
Thanks
geposted Wed 26 Dec 07 @ 4:38 pm
Previous to R4
Rev + 4 and 6
go to remotes > and enable general midi and right click and press options, and press add
You will now see a list of possible actions for each button or slider , each option is explained on screen.
Repeat these steps until , the console is mapped to your liking ,you may also find this link helpful it is a midi number list for each button.
http://www.numark.com/stuff/contentmgr/files/9e0e1954f2b6a7df5d19e96a4994163a/file/totalcontrol_midimap.pdf
Rev + 4 and 6
geposted Wed 26 Dec 07 @ 4:43 pm
Thanks skyfxl. You always have the answer.
I ‘ll check it out in the AM. I’ll get back to you on my results.
geposted Wed 26 Dec 07 @ 4:48 pm
The link this.
Total Control are permanently set and not
adjustable.
Dose this mean that the controler can't be re-mapped?
adjustable.
geposted Wed 26 Dec 07 @ 5:13 pm
That means you cant change the midi numbers some applications have a preset list of what notes should do and this is not changeable .
However as vdj works on assigning an action to a midi number this isn't a problem
as you can set any action to that one number in vdj options.
geposted Wed 26 Dec 07 @ 5:22 pm
thank.
I quickly attempted to change the effect to video but nothing seemed to happen but will spend some time after my gig tonight.
thanks
thanks
geposted Wed 26 Dec 07 @ 5:29 pm
