can you listen to a song only on headpones and not on main mix. I need it to be just like a real mixer.
thanks
thanks
geposted Wed 26 Dec 07 @ 5:37 pm
yes. but you need a soundcard that has two seperate stereo outputs for that, or a system with two soundcards
Easiest solution, would be to get a decent usb 4.1/5.1 soundcard (surround)
geposted Wed 26 Dec 07 @ 5:41 pm
what if i already have 5.1 onboard.........i played around the sound confiig also. i thought it would be easy and just hit the PFL button and that would only be heard on the headphones.
thanks
thanks
geposted Wed 26 Dec 07 @ 5:44 pm
Its pretty easy yes ;)
In VDJ soundcard setting tab, choose speaker + headset.
That will give master out at one of your outputs (usually channel 1/2 at a 5.1 soundcard), and headphone out in a different output (usually rear out, at a 5.1 soundcard)
geposted Wed 26 Dec 07 @ 5:46 pm
thanks for your help!!!
i have done this and the music that comes out of my headphone is the same as the master.
geposted Wed 26 Dec 07 @ 5:51 pm
Look at the PFL buttons next to crossfader in the skin (if default), or use the TAB key to choose deck.
If you are on the SAME deck as whats played out as master out, you are listening to the master out (kinda), if you switch prelisten (cue) to the other deck, you should hear that deck...
does it work?
If not, wrong setup
geposted Wed 26 Dec 07 @ 5:53 pm
think i got it..................now this is going to be an awsome new years
thanks!!!!!!!!!!!!!!!!!!!!!!!
geposted Wed 26 Dec 07 @ 5:59 pm
Have a rockin New Years ;) mix it up! ;)
geposted Wed 26 Dec 07 @ 6:02 pm
