Hi
I was using using VDJ 5 rev 5 just fine and then my hard drive (running the OS) failed.
Luckily i've managed to recover all the VDJ data from it.
After getting a new Hard Drive and then installing VDJ 5 Rev 6, i'm know tring to get everything back to how it was, which i've done fine except for one thing.
Where i had the entire history (built from Autosaved playedlists), i have copied the history.txt file to the My Documents/VDJ folder, but this doesn't seem to work.
I then noticed there was a tracklist.txt file in the Tracklist folder which seemed to be in the same format as the history.txt file, so i renamed my history.txt file to tracklist.txt and saved over it, this also didn't work.
Any ideas on how i can get all my old history back into VDJ??
Many Thanks in advance
geposted Fri 28 Dec 07 @ 1:40 pm
