IS THA BEST!!!!! i had it for a while but never felt like installing it. with tha previous driver, 1.16 i think, tha sound would cut off and all that and had NUTHIN but problems and just stopped messing with it. but now with tha new driver i can have it at 2ms latency and didnt shut down ANY programs like the firewall and the sound NEVER cut off in tha hour that i played with it. i got a lil bit of sound interference with the output but i'll try n work on that later
if anybody has the u46dj and has sound problems try the new driver but the only problem is that the driver is only for certain models, check tha ESI website for more info.
PROPS to ESI and now i cant wait for the VISTA driver.
geposted Sat 29 Dec 07 @ 1:36 am
Hey what's up man. Do you have a link to the download?
geposted Sat 29 Dec 07 @ 8:47 am
geposted Sat 29 Dec 07 @ 8:51 am
I will give it a thumbs up! it has a slightly different setup where i no longer see the ASIO config from inside VDJ but rather its found on the u46 mixer panel. It has been running as smooth as 1.016 has for me and the improved latency is a nice plus.
Give it a shot. 1st make sure you uninstall the old driver.
Aftermath: it ran pretty good BUT i could not find a way to get rid of some small static i was getting. I might have if i were to drop my VDJ settings but that is useless since 1.016 runs fine at almost max quality.
The new driver does have a different config menu so there could have been something i missed but i tried a lot.
geposted Sat 29 Dec 07 @ 11:41 am
