I installed everything. But only problem is, when I play a song, I cant hear anything from main speakers, I only hear from headphones. How can I fix it? Please help.
geposted Sun 21 Nov 04 @ 10:03 pm
this might be due to a cracked version, as they cause problems, have bad code...
please uninstall all cracked version, and reinstall clean the console version.
That should fix any problems
geposted Tue 23 Nov 04 @ 12:48 pm
same problem here, but my version is clean
i guess the program takes the soundcard from hercules as main soundcard, but my surround system is attachted to another soundcard
can't you change anywhere wich soundcard should be used?
geposted Tue 23 Nov 04 @ 6:01 pm
@soepermein
Do you have the console version or the demo version of Virtual dj?
You can change soundcard in demo version.
Make sure you choose the hercules console at soundcard setting, brownse down to you see the image of the console, and choose that.
hope that helps ;)
hope that helps ;)
geposted Wed 24 Nov 04 @ 3:59 pm
