For you guys that want a simple solution to adding live video cameras to your system, try this.
http://www.amazon.com/ADS-USBAV-192-EF-Movie-Capture-Xpress/dp/B000MTUQKS
Thing works excellent, plug any camera you want into it and shazam you have live feed.
r
r
geposted Sun 30 Dec 07 @ 5:34 pm
I've tried several cameras and several user-created plug-ins, but I still haven't gotten a live feed to work THRU virtual DJ. The closest I've gotten is with a plugin that displays the video upsidedown and backwards. (hanging the camera upsidedown from my light truss gave a cool effect - MirrorVision!! - patent pending so don't even think about it!)
Let me know if this works thru VDJ, and how the setup works.
JMC
JMC
geposted Fri 22 Feb 08 @ 5:07 pm
I have it working fine, will post my solution later. I'm getting ready to pack up.
geposted Fri 22 Feb 08 @ 5:13 pm
I already have the ADS Capture Card, works great for video capture but I've never thought about using is as a live feed device. I don't camera that uses RCA inputs, what do you have?
Thanks :^)
Thanks :^)
geposted Sat 23 Feb 08 @ 9:34 am
The capture device will import s video and rca/composite
I use the Sony D100 with a wired remote control.
Thing is wicked
You could plug any video source into this device.
I plan on testing and using the Numark NuVJ with it today.
http://nuvj.arkaos.net/nuvj/product_overview.php
Thing is wicked
geposted Sat 23 Feb 08 @ 9:55 am
The last time I tried using a camera feed thru VDJ, it would cause VDJ to simply dissappear. Not sure exactly which version it was, but was with a version previous to 5.0.4.
Has this been fixed or is there something I'm doing that was causing it to go POOF!?
geposted Sun 24 Feb 08 @ 10:56 am
my camara worked since day one , i can even watch the bars security camaras through virtual dj.. its cool ,, love adding the effects...
geposted Sun 24 Feb 08 @ 11:16 am
OK, so maybe I have an issue. What should I look at? I just installed the nov 07 DirecX, what else should I check?
geposted Sun 24 Feb 08 @ 11:19 am
