I am using TCCDs with a DAC3 version 5ver6 and would like know if; 1: It s compatible with version 3.4 and 2: If I can disable the jog wheels since i am using TCCDs...
geposted Mon 31 Dec 07 @ 10:31 pm
My DAC-3 mapper includes a DLL that is still compatible with VDJ v3.4 - https://virtualdj.com/addons/download.html?addon_id=2401
Amongst many other things, it allows the jogwheels to be toggled between scratch and pitch bend (I.e: Less noticeable if you accidentally touch the jogwheels.) You can also adjust the sensitivity of the jogwheels in each mode.
NOTE: Future versions of the mapper will not support versions of VDJ prior to v5
geposted Tue 01 Jan 08 @ 7:08 pm
