Good Morning all,
I have tried both versions of virtual dj pro and newmark cue pro, and I am still not able to listen to my mix prior to blending the songs together?
Do the programs have this capability becasue I still have not purchased the programs because of this issue.
Can anyone advise me on how to do this before I purchase the product.
Thank you for your time.
Jason
Jason
geposted Wed 02 Jan 08 @ 7:28 am
You require a 4.1 sound-card or better with two outputs or more to allow headphone previews.
geposted Wed 02 Jan 08 @ 7:33 am
still not sure what you mean (sorry). I am able to listen to either turntable but with the newmark total control all In have to do is press the a button at the top corners on either side to listen to my mix prior to my blending of the tracks.
I don't recall that ability in the pro version of virtual dj. I can listen to my blend if I have the fade control in the middle and yes I can listen to my mix, but if I was recording it would not sound good if I miss a beat.
geposted Wed 02 Jan 08 @ 7:47 am
The mapping is the same for le and the latest pro version , so you can use the headphone option in the same way.
you will need a sound-card with more than one output one for the headphones and one for the main mix.
geposted Wed 02 Jan 08 @ 8:53 am
not sure if this helps or if what you actually require, using vdj to prelisten left and right decks without an external sound card.... did this earlier for youtube so is a bit fuzzy
basically if you cant follow the clip
go to config
soundsetup
outputs > external mixer
soundcards > mono seperated
output channels give you white lead/left channel red lead/right channel to your mixer
you will have to use a y splitter for each channel to get dual inputs into mixing desk
which of course will only give you mono sound output to speakers
hope that is of some help to you
Tayla
geposted Wed 02 Jan 08 @ 12:47 pm
thanks tayla, much appreciated the help.
geposted Wed 02 Jan 08 @ 8:03 pm
scorpius
no probs, glad your sorted, but it would be better for you if you follow skys advice at a future date...
Tayla
Tayla
geposted Thu 03 Jan 08 @ 7:13 am
good morning tayla,
sky's advise was not the issue. I have a sound card that is capable of that function, it was the pfl problem..... I have taken your advise made the changes and I was groveing last night.
Thanks once again.
Jason
Thanks once again.
Jason
geposted Thu 03 Jan 08 @ 7:39 am
continue......
I will be now buying the pro edition. Love this program!!
geposted Thu 03 Jan 08 @ 7:40 am
glad to hear it on both counts jason
let me be the first to welcome you to the pro side
Tayla
Tayla
geposted Thu 03 Jan 08 @ 7:47 am
