brand new in a box unused unopened and so is shop perfect
came across this, this morning while finally getting to put the pc back in its room after decorating it (the room) it was for a project that i did'nt get round to doing
would like to swap it for some controller for vdj as i think i should really get rid of the mouse, lol, and really want to try something out before i splash the cash on something more exotic, would condider anything that is compatible and is in fair condition with all its lights and whistles working, also need it to video crossfade
what it says on the box...
send your pc's video output to as many as eight monitors sharp, with ability to daisy chain for more(i read 64 somewhere) ideal for your presentation to reach wide audience at a distance of 210 feet away (65metres)and much more applications.
compatible to multisync, svga, vga, ega, and cga monitors
value when bought £50
Tayla
Tayla
geposted Fri 04 Jan 08 @ 3:02 am
Hi Tayla
To be honest i think you might struggle to get someone to take you up on your offer.
Even the very cheapest of DJ Software controllers are well above £50 new, and they all seem to have slow depreciation. Many people hang on to them as backups even if they don't use them.
I'd recommend selling your VGA Multiplier on Ebay, along with a few other bits and then plump for the Numark Total Control if possible.
You can buy a NTC from the states (new) for about £100 (more like £170 here in the u.k), as the device is USB powered there are no power supply issues.
The NTC is a decent bit of kit which is much more comfortable to use than the Hercules Mk2. IF on the other hand you find having a soundcard/mixer/controller all-in-one combo device useful, then the MK2 could be the one for you instead as the NTC is a controller only. Neither are really any good for scratching though.
geposted Fri 04 Jan 08 @ 3:28 am
thanks for the post digi
was basically looking for something like an old hercules (which are only £70 quid new) or along those lines so i could get used to the gizmos and stuff before i commited my self to something in the higher end of the market, just needed something to mix with and is compatible with vista
but your advice taking on board thanks again
Tayla
Tayla
geposted Fri 04 Jan 08 @ 3:39 am
You northerners are tight sods ain't yeah....Hehe,
All the money you're on, go mad in your old age and splash out on something decent, lol
Jimmy b
Jimmy b
geposted Fri 04 Jan 08 @ 10:29 am
ah know, thats how i got this multiplier just on a whim, "no use to me now i'll end up giving it away". err, that last statement is not exactly true if you know what i mean...lol
and theres no truth in the rumour my wallets on a yearly time lock either, just ask santa
and what do you mean if the titanic was as tight it would still be afloat
Tayla
Tayla
geposted Fri 04 Jan 08 @ 10:39 am
Tayla
Tayla
He meant Tatianna, not Titanic.
geposted Fri 04 Jan 08 @ 1:17 pm
LLOL, suprisingly for a big girl
geposted Fri 04 Jan 08 @ 1:45 pm
