Just a quistion:
I have the actual version of VDJ pro and last week I worked with
the autoplay function. I added music files to the playlist and sometime
I pressed the "Save" button. After 30 min. I want to add some filed fileds but my
playlist was empty! So I´m searching for the "restore" button because I
saved it several times but I can´t found it.
- What happend here and why could it be that the playlist was empty sudenly?
- How can I restore the playlist that I saved before? (right window whre I can
set autoplay ot on/of etc.
Thank you for your support.
Regards,
Helmut
Regards,
Helmut
geposted Sat 05 Jan 08 @ 4:25 am
When you want to save a playlist it will ask you to name it.
Once you name it you click OK and it saves it in the playlist folder.
When you want that playlist again just go to playlists and choose whatever you named it as.
If you did not name it it may not be saved.
geposted Sat 05 Jan 08 @ 8:09 am
OR when you went to name it it overwrote the .m3u at the end, do a search in your computer for the name of the file and find it and make sure it has .m3u at the end of it.
geposted Sat 05 Jan 08 @ 11:33 am
I have added songs over years to a playlist that a named pop, today I come to use it and it’s empty. How do I get all those songs back?? Please look
geposted Sat 18 Aug 18 @ 10:54 am
Just restore the file from one of the regular backups you made of your system.
You did keep backups, didn't you?
geposted Sat 18 Aug 18 @ 11:43 am
http://listfix.sourceforge.net/
this is playlist fix
geposted Sat 18 Aug 18 @ 6:02 pm
