Got a laptop, How do I pre-listen?
geposted Wed 24 Nov 04 @ 2:18 am
Go to advanced configuration in sound card tab
then set preview box to primary sound card
hope this helps
Andre
hope this helps
Andre
geposted Wed 24 Nov 04 @ 6:58 am
So, will that work with the on-board sound card?
geposted Wed 24 Nov 04 @ 7:35 am
yes it will ...do you have only one card?
geposted Wed 24 Nov 04 @ 7:36 am
It will work with only one sound card, but you will need to split the output.
This requires a stereo splitter. A cable with the headphone jack on one end, and 2 rca plugs on the other end.
geposted Wed 24 Nov 04 @ 3:01 pm
Yes, I have only one on-board sound card.
I'm looking to make a small set-up (after hours office fun)
but i'm a serious music collector and my passion is mostly electronica - Leftfield, Sasha, Thievery Corp., etc.
I've got a set of Logitech thx 400w multimedia speakers that crank and would like to start recording some mixes smoothly and professionally with VDJ.
geposted Wed 24 Nov 04 @ 4:57 pm
Also, my laptop has only one headpnone out jack.
geposted Wed 24 Nov 04 @ 5:45 pm
u should buy an external usb or firewire sound card, and u'll have pre-listening and the chance of use an external mixer.
I own a Creative Extigy and works great.
geposted Wed 24 Nov 04 @ 6:15 pm
You plug the splitter into the headphone out jack. Then you plug one of the rca ends into your speakers. (some adaptation may be required) Then you plug your headphone into the other rca end. (adaptation will be required)
Chose in sound configuration, 1 sound card/headphone speaker.
geposted Wed 24 Nov 04 @ 6:29 pm
Thanks very much!
(nice to there's cool people out there)
geposted Wed 24 Nov 04 @ 7:58 pm
i am using a virtual dj 2.02. on my laptop.can anybody tell me how to configure this software using usb creative labs sound blaster. my objective is to be able to hear my tunes through the headphone before playing through main audio
geposted Fri 26 Nov 04 @ 2:59 am
yes i have two soundcards. one in the laptop and 1 external usb creative labs extigy soundblaster but i just cannot get to prelisten to it interferring with the main audio. how do i do a proper configuration. step by step please
geposted Fri 26 Nov 04 @ 3:05 am
mandeville: That feature is disabled in the trial version.
geposted Fri 26 Nov 04 @ 3:27 pm
