Please Help Me Decide
in a few days i will order a new laptop.
and i have to decide what system will be installed on him
till now i was working with Xp, and i had a litlle problem only with nVidia memory but I fixed the problem with Riva tuner.
I am using tcv's and I'am always playing videos.
Please share with me your problems specialy if you ware using Vista.
My Best Regards
My Best Regards
geposted Thu 10 Jan 08 @ 8:22 am
XP, I heard of alot of people having problems with Vista especially after the update came out. I have never had a problem with XP, that is why I got it on my new laptop.
geposted Thu 10 Jan 08 @ 8:45 am
XP. Vista was really not ready for prime time. It might be a little better once Service Pack 1 comes out, but if you have a choice and your hardware will support it (Believe it or not, some new hardware will not load XP because there are no drivers for the mainboard.) go XP.
geposted Thu 10 Jan 08 @ 11:10 am
Go for Xp, a more safer choice at the time
geposted Thu 10 Jan 08 @ 11:23 am
xp pro
geposted Thu 10 Jan 08 @ 11:27 am
Vista does have an improved video and audio api meaning audio and video is handled better , alot of people where waiting to SP1 to adopt but the update was a bit of a flop.
If your happy with xp and worry about upgrading , remember the number one rule of Computers " if it aint broke dont fix it" .
however , its important to check what your new laptops hardware supports as cards with dx 10 support work best on vista , and some companies arnt releasing xp drivers for their newest hardware.
geposted Thu 10 Jan 08 @ 12:13 pm
I thought the number one rule of computers was "release an update so that we can meet our quarterly sales quota!"
I'd recommend XP Professional. Seems that a lot of people (including myself) have had audio problems with Vista. XP is safe, works great, etc.
Vista has a nicer installation and has some really nice features, but there are big issues with it right now. If Vista SP1 solves the worst of the issues (and it dosen't look like it's going to be a big change at this point) maybe we'll just have to wait for Windows 2010 or whatever, which will probably be released sometime in Q3 2015.
geposted Thu 10 Jan 08 @ 3:20 pm
XP Professional
geposted Thu 10 Jan 08 @ 3:31 pm
spinnaJ wrote :
XP Professional
+1
geposted Thu 10 Jan 08 @ 3:52 pm
vista if u have 8 gb of ram is great (xp if u have 2 gb and lower
geposted Thu 10 Jan 08 @ 5:18 pm
I'm with XP, not going to think about Vista till microsoft release SP2, hopefully all the bugs will be out of it by then.
Jimmy b
Jimmy b
geposted Thu 10 Jan 08 @ 5:27 pm
i would have to pick vista for VDJ and video mixing.
when using the same system w/ windows XP, my video was constantly freezing. i believe this is more of an nvidia issue.
for everything else I would choose XP.
geposted Thu 10 Jan 08 @ 5:31 pm
XP is the best software to use. Vista has too many programs that are incompatable. look in U tube and type up vista nd you will see what i mean..
geposted Thu 10 Jan 08 @ 8:03 pm
actually I´ve read somewhere that MS is already on their way to develop a new OS, it has the project name windows 7
geposted Thu 10 Jan 08 @ 8:43 pm
Ok You Helped me. BIG THX
But onlu one more question what is the difference betheen XP Home Edition and XP Proffesional
and are these diferences has any effect on working with VDJ?
geposted Thu 10 Jan 08 @ 9:02 pm
My desktop system was built for Vista, but after installing OK, arter Post, system just reboots over and over and never makes it to the Microsoft screen at all, even after reinstall same issue!
Stick with XP Pro!
Stick with XP Pro!
geposted Fri 11 Jan 08 @ 3:07 am
I have 2 laptops, my main Laptop i have XP Ultimate on it and it works GREAT, my VDJ and Denon HC4500 run Great on it(Midi). On my Back Up Laptop i had Vista on it..it sucked.....but since i add Vista ULTIMATE its Awesome....no problem with VDJ it runs GREAT with Video too....I been using my backup laptop for 3 weeks straight now for all my gig and radio shows and NOOOOO Problem.......Vista Ultimate is AWESOME!!!!!!
I saw if you have to used XP or Vista used the Ultimate editions...they are great ,......cause i used XP Ultimate and Vista Ultimate
geposted Fri 11 Jan 08 @ 7:49 am
I was not aware that there was a version of Windows called "XP Ultimate".
In many respects I like Vista Ultimate, but there are always far more technical problems using a Vista system (at the moment). If things are working okay, then it is better than XP due to the new features the OS brings, and is substantially modernized, but these aren't exactly real critical. I can certainly live without the sidebar and the start menu search, for example.
As for the difference between pro and Home for Virtual DJ - not that much difference. Professional allows more security and configuraiton, allows remote desktop, and better filesharing, allows domain login, etc. For most DJ scenarios this is probably a nonissue, but if security and networking functionality are important to you, then Pro will make life much easier. Home just seems so castrated to me sometimes.
geposted Fri 11 Jan 08 @ 1:55 pm
there is no such thing as xp ultimate. do a search and you'll find that it exists on torrent sites only. so some nimrod has probably slipstreamed an xp iso with updates and hacks and probably some funky bloatware and repacked/named it as ultimate.
might be worth checking out anyway if you arent hack-savy because there are alot of cool things to streamline on xp.
geposted Fri 11 Jan 08 @ 3:32 pm
