Hi all,
can someone link me up where I can find a description how to setup m-audio conectiv and TCCD for Pio CDJ-1000 MKII (no MP3 Version)?
or: who has set this up and can give advise?
what do I have to be aware of when converting the tccd.mp3 into wav ?
config:
Pio CDJ-1000 MK2
Pio DJM-600
Intel Core-duo 2,4 Ghz / 2 GB DRAM / USB 2.0
M-Audio Conectiv
config:
Pio CDJ-1000 MK2
Pio DJM-600
M-Audio Conectiv
geposted Fri 11 Jan 08 @ 1:36 am
Hi there use a cd burning application like nero or even windows media player to burn an audio cd with that signal.
For setup on sound options choose
Inputs : dual timecodes
Outputs : External Mixer
Card : Asio
Driver : M-Audio - Conectiv
then enter timecode options , play the signal and press autoconfigure the settings will be automaticaly set so you get 100% quality.
Now on performances choose Autolatency
Card : Asio
geposted Fri 11 Jan 08 @ 9:51 am
Thanks for the info - let's start :)
geposted Fri 11 Jan 08 @ 11:24 am
runs perfect! Thank U
geposted Sat 12 Jan 08 @ 8:57 am
Your most welcome hope you enjoy it :)
geposted Sat 12 Jan 08 @ 9:19 am
I just get this setup , it works but when I am mixing two songs together the music will skip
and sometime time code will stop working.
my setup is
2 Denon DN-S5000
M-Audio Conectiv
Laptop
Gateway M505
Pentium M 1.5 GHz
1GB (DDR SDRAM)
Is there something I can try or do?
thanks
my setup is
2 Denon DN-S5000
M-Audio Conectiv
Laptop
Gateway M505
Pentium M 1.5 GHz
1GB (DDR SDRAM)
thanks
geposted Fri 25 Jan 08 @ 11:01 am
