I am a relatively experienced user of mp3 mixing softwares , i have used almost all the variety of mixing software available so far ranging from mixers in linux etc.However i have grown attached to the line of mixers produced by the virtual dj /atomix group.
MY problem is however , after using virtual dj 1.02 i had no problem with the soundcard confiids for my system with dual soundcards until i switched to virtual dj 2.0 , I cannot configure my system to make use of both soundcards while mixing as i could do previously. Therefore i am asking for some form of assistance in fixing this problem. THANK YOU.
geposted Thu 25 Nov 04 @ 5:25 am
It's normal, a cracked version cause this problem.
Now you have to purchase a legal version to fix it.
geposted Thu 25 Nov 04 @ 7:24 am
I am not sure if you bought the software or not but if you did you should update to the newest version it will help. If you didn't buy it you should. It is well worth the small investment.
geposted Thu 25 Nov 04 @ 7:25 am
