Hi, I was just wondering if VDJ will interface with the midi functions of the Pioneer CDJ400?
geposted Sun 13 Jan 08 @ 6:57 am
You can map the midi functions on options > remotes > midi
Prior to 5R5
5R5/6
Right Click on General Midi and press activate , then click configure.
All Versions :
Each possible function is explained on screen.
Native support will hopefully be added soon also.
Prior to 5R5
5R5/6
All Versions :
geposted Sun 13 Jan 08 @ 8:10 am
Pioneer should also be releasing ASIO drivers for the CDJ-400 soon, so you can use it as a soundcard too.
geposted Sun 13 Jan 08 @ 12:23 pm
has someone already made a mapper?
can't get my jogweels well to work.
geposted Thu 17 Jan 08 @ 12:22 pm
