I have VDJ installed on my laptop, which i take to gigs etc, working like a charm.
I noticed the DVD-rip program, to rip dvd's to videofiles.
Can i install VDJ with the same serial, so i can rip the dvds on my normal workstation? (my normal workstation is way faster)
geposted Mon 14 Jan 08 @ 6:53 am
yes, u can as a PROFESIONAL USER, u can installed up to 2 com at one time;)
(2pc or 2mac or 1pc & 1mac)
geposted Mon 14 Jan 08 @ 7:01 am
ronnie
your license allows you to install on two computers, but you may want to consider using different ripping software to vdj as many of the guys have elected to do, theres lots out there i use avs media, its quick and gives good audio and video quality and is simplicity itself to use,
check my blog theres an easy to follow video there that i did and only lasts four minutes and in that time i tagged and ripped two vids, theres also a blog by tophouse that you may want to look at... hope that helps
you can get a free demo here http://www.avsmedia.com/ and if you need any help just give me a shout
Tayla
Tayla
geposted Mon 14 Jan 08 @ 7:06 am
