the one shown here
http://www.chemical-records.co.uk/sc/servlet/Info?Track=MVV2BOR
is it possible?
thanks!
is it possible?
thanks!
geposted Tue 15 Jan 08 @ 7:09 am
No only VDJ , VV replacements are currently supported unless a user creates a plugin to support that vinyl.
geposted Tue 15 Jan 08 @ 8:31 am
ok, and what about the numark replacement vinyl listed here: i guess its the same as vdj timecode vinyl
http://www.dancegrooves.com/cms/shopprodukt/80983/timecode%20vinyl%20for%20virtual%20vinyl.htm
is it ok?
thanks for help.
is it ok?
thanks for help.
geposted Tue 15 Jan 08 @ 2:35 pm
Yes, u could use that;)
geposted Tue 15 Jan 08 @ 2:39 pm
Are you positive numark replacements work? I bought some and can't get them configured and no one on this board seems to know. I've also read about other people having problems with them, mostly 0% signal. I only get a 0% signal and have followed all the tutorials on the board.
geposted Tue 15 Jan 08 @ 4:24 pm
Yes they are the same vinyl , what version do you use?
geposted Tue 15 Jan 08 @ 4:37 pm
menappi
If you are looking at getting the Numark vinyls and live in the UK, they are rarer than Rocking horse shit. Had some on order, but phoned up today and cancelled the order, as the place where I was getting them from told me Numark are stuggling to deliever them and won't be till the end of the month.
Might aswell wait till VDJ TCV's are ready, it won't be long. That's what I'm doing.
Jimmy b
Jimmy b
geposted Tue 15 Jan 08 @ 5:15 pm
you can get them delivered in a day from www.decks.co.uk
geposted Wed 16 Jan 08 @ 7:27 am
That's where I had mine on order from Sky, their website say's there in stock but there are not.
Won't be getting any tell end of the month. That is what I was told by them
Jimmy b
geposted Wed 16 Jan 08 @ 9:13 am
