OK guys, what is the best way to print the recordcase? I need the Artist, Track name, and Bpm listed. Thanks.
Killabee44
Killabee44
geposted Thu 25 Nov 04 @ 7:45 pm
mixmeister opens in notepad,does bpms and you can tag all you want
geposted Fri 26 Nov 04 @ 10:30 am
Don't know if I understand weel. If you want a listing with all your songs just open "mp3database.txt" for exemple with Excel and edit the columns you want to keep.
Clax
Clax
geposted Fri 26 Nov 04 @ 4:16 pm
Clax, you mean the Virtual DJ Database.xml no?
I did try but there is a ton of data scattered all over the place as well as all sort of miscellaneous characters. The data is not in collumns. Also, the BPM seems to be coded.
Open it with Excel and you'll see what I mean. I really wish we had a utility that we could use to do this.
As far as the Virtual DJ Database.txt goes, I opened it with Excel and the data is not in collumns. Also does not store the BPM's.
Andre, I have corrected thousands of BPM's. Many that Mixmeister had wrong, so I want the values in the Virtual DJ Database.xml file to be in the print-out.
Man I wish there was a utility that could do this!
Killabee44
Killabee44
geposted Fri 26 Nov 04 @ 9:29 pm
I was speaking about "mp3database.txt" but this file does not have any BPM info.
"virtualdjdatabase.xml" has the info but it's not easy to arrange columns.
May be someone could create a small soft to create a list from this file ...
Good luck.
Clax
Good luck.
Clax
geposted Sat 27 Nov 04 @ 1:08 pm
