1) How do I clear my History folder?
2) I set my main windows directory called VIDEOS as a favorite folder in VDJ. When I expand this and browse through the sub folders in VDJ, iI cannot get the columns to get into alphabetical (or BPM) order when I click the column heading. What would cause this? It used to work...
geposted Fri 18 Jan 08 @ 11:15 am
Don't know about your first question Eric, but your second one, go to the download section and grab yourself DJ cels regirstry tool,
Once D/L put it in My Docs and open it up. What I did to get my files in alphabetical order was to change some setting with in it, on cstoll advice.
Just look for these
Autosort, change to 3
Sort order default, change to 0
Sort orderforce, change to 3
I hope you get this, lol
Jimmy b
geposted Fri 18 Jan 08 @ 11:33 am
Hmmm... it just started working again. I'll download that anyway for future... thanks.
geposted Fri 18 Jan 08 @ 1:45 pm
In Windows click on Documents or My Documents....Find Virtualdj....click on that.........Then you should see Tracklisting...click on tracklisting clear the dates you don't want or clear all of them............ hope this helps Bob
geposted Fri 18 Jan 08 @ 2:55 pm
Yes - that worked. Thanks.
geposted Fri 18 Jan 08 @ 4:59 pm
