It used to be that when you "hover" your mouse over the individual clips in the clipbank, they would play as a preview inside the bank itself before going live. I see that this no longer happens in version 5.x. This was a beautiful feature... was it removed?
I'm using clipbank version 1.2.
geposted Fri 18 Jan 08 @ 1:10 pm
Yes, it was removed.
geposted Fri 18 Jan 08 @ 1:27 pm
eric
you can still get it from the plugin section if you prefer that version
rick, they brought it back on board
eric if your wanting some ambients for clipbank watch the forum tomorrow, haven't got time tonight to put them on got to get to gig
Tayla
Tayla
geposted Fri 18 Jan 08 @ 1:29 pm
Would that be the 1.1 version? And just curious... why would that be removed as a feature???
geposted Fri 18 Jan 08 @ 1:47 pm
yeah the original, have a look... sorry gotta go
Tayla
Tayla
geposted Fri 18 Jan 08 @ 1:50 pm
Thanks Tayla. I just downloaded and installed the OLD version. But still no hovering play effect.
Any ideas?
Any ideas?
geposted Fri 18 Jan 08 @ 1:56 pm
I think it was a stability, and resource issue. The hover was using resources when it was not needed.
geposted Fri 18 Jan 08 @ 2:00 pm
did you dump the other version, from everything, best to to follow directions from rick or cel, i would ...
Tayla
Tayla
geposted Fri 18 Jan 08 @ 7:41 pm
When you say dump, you mean delete the clipbank folder under My Documents/Virtual DJ? I just re-installed over the old...?
geposted Fri 18 Jan 08 @ 7:55 pm
eric
not sure if this is the easiest or quickest way, take both programmes(uninstall) out of your pc/lappy and reinstall the original version of clipbank,hopefully that gets you back to what you want
Tayla
Tayla
geposted Fri 18 Jan 08 @ 9:24 pm
