Hey everyone im using virtual Dj 5.0 and numark cue 4.1
I purchased the Icue Computer Dj system and its not working with either program
Can anyone provide me with some help here? Im totally bummed out :(
geposted Fri 18 Jan 08 @ 8:23 pm
Can you elaborate, please?
What are the symptoms, exactly?
geposted Fri 18 Jan 08 @ 8:30 pm
elaborate?
the ion icue doesnt work with numark cue 4.1 and virtual dj 5.0
it doesnt do anything when i load songs. I cannot control them with the ion icue.
Did that help any?
Did that help any?
geposted Fri 18 Jan 08 @ 8:31 pm
did you try turn on the controler in the config menu under controlers
geposted Fri 18 Jan 08 @ 8:39 pm
i will check and let you know
geposted Fri 18 Jan 08 @ 8:45 pm
YAY!!!!! THANK YOU!!!!!
geposted Fri 18 Jan 08 @ 8:46 pm
BlakeB wrote :
elaborate?
Did that help any?
Did that help any?
Okay, that's a bit clearer than your first post. Not being there with you, I cannot anticipate nor assume what is (not) happening. Detailed descriptions are so much more helpful to work out the problem.
So, you can get a song to load, but it doesn't play at all, right?
Are you using a controller, or just the onscreen commands?
geposted Fri 18 Jan 08 @ 8:51 pm
Oh well, guess ya beat me to it :D
Glad you got it straightened out!
geposted Fri 18 Jan 08 @ 8:52 pm
its already been fixed i didnt know i had to turn it on in the config menu. Thanks for all your help!
geposted Fri 18 Jan 08 @ 8:53 pm
