Ok sorry, if anyone has any input please help me, i've run out of ideas.
My setup-
SB audigy 2 zs plat pro sound card
TCV-external mixer
Got everything hooked up, left tt/virtual deck will play mp3s no problem, 100% signal. I set up the right deck, got 100% signal, seems fine. Until that is..I load a song on to the virtual deck. Then I try to play and it plays super slow, very distorted and garbled up. When there's no mp3 I can see the turntable spinning fine onscreen, when a song is on, it is jerky and slow. What is up? I can't even heard the music when I play it on deck two, just a buncha random noises, sounds like someone is blowing in a microphone. If i turn TC off then the song plays fine on that channel.
Extra info-
the working tt is hooked up to the soundcard in one of the line ins, the second non working one is hooked to the rca inputs. I grounded the nonworking TT on the computer chasis, although this didn't seem to be a problem. have the card set up for 4.1 sound, tried to go into the options and enable aux and different line ins with different combos, doesn't work.
My setup-
TCV-external mixer
Extra info-
geposted Sat 19 Jan 08 @ 12:49 am
ALSO- if I am playing a song on the working deck, or even trying to set up the signals, the right deck (non working) shows some activity and makes noise. So lets say nothing is playing on both, play something on the working deck, and i can hear some garbage coming out of the right one, very faintly though. Maybe there's something special I need tod o to enable both inputs at the same time? Id unno
geposted Sat 19 Jan 08 @ 12:51 am
heres your solution
http://www.virtualdj.com/buy/
geposted Sat 19 Jan 08 @ 6:28 pm
why don't cha download the demo , and save up for 20 days and buy it ? you'll be glad you did .....
geposted Sun 20 Jan 08 @ 11:07 am
Pointing me to a link to buy the program isn't helping me, and I am using the DEMO. If i can't get it to work, why in the hell would I purchase it, which is why I'm using the demo as of now, with limited time to test it out. Problem is with the right deck..anyone?
geposted Sun 20 Jan 08 @ 10:30 pm
Menappi, i have the audigy 2 zs platinum pro but i would not use it for timecoded. It not a soundcard but more to audio interface. Even if u managed to get it done u can only get it to run on one deck only but i would recommended this as it a bit pain in the ass trying to tweak n configure this. Get any 4 in 4 out soundcard n u be fine. Such as maya44usb, u46dj or even the herc mk2 n of course the legit pro will also help contributing to ur needs;)
Regards.
Regards.
geposted Sun 20 Jan 08 @ 10:44 pm
There should be a way though to get this card to work, i've read on the forums tha tpeople use it for tcv. It's even listed on your list of sound cards that will work. It has 6 stereo inputs, why would only one work with the tcv? Do i need to change the registry? I'm fully capable of making advanced configurations to my computer, i just don't know what to do. I want to be able to mix completely digital with the demo before I drop a chunk of change on this stuff.
geposted Tue 22 Jan 08 @ 9:19 pm
menappi: You may need to make some registry changes. Try messing around with the different configs. You should be able to get both timecode working on both decks, you may want to change the settings in performance to fast, and see if that helps you out any. On certain configs tho, you need to make registry changes if your using different inputs/outputs on your soundcard....search the forum...I posted something back a while ago regarding the ecler nuo 4 and Motu Ultralite.
geposted Tue 22 Jan 08 @ 10:13 pm
