do you guys now if this can be used vdj using a sound card.. it has great features you would look for on vdj
pitch bend, key lock and very easy to use
let me know thanks
let me know thanks
geposted Sat 19 Jan 08 @ 4:09 am
Unfortunatley they are not compatible , there is only one output from the mixer so it would not be possible to use the time codes also there is no scratch mode.
geposted Sat 19 Jan 08 @ 4:43 am
