I think this happened to me last update and hope it's one of my settings in windows. VDJ does not save what I have done on exit. What I mean is if I analize songs for bpm's they are gone on exit. They no longer save. Everything I previously did is there nothing new. If I change a skin it stays. If I drag the song into the player and it analizes it seems to stay. I used the mixmeister program to analize the tracks. Could this be an issue?
geposted Sat 27 Nov 04 @ 2:07 am
Yes, mixmeister is the problem, it changed tags, and filesize
of your songs. Vdj dosn't recognise them anymore (it uses
filename and filesize to recognise songs in the database)
I have all my files set as "read only" to avoid other programs
write on them.
write on them.
geposted Sat 27 Nov 04 @ 4:58 am
What can I do? Do I wipe ot and use the new engine to try again?
geposted Sat 27 Nov 04 @ 5:18 am
If someone reads this.. Can I just rescan and everything will be ok with the new BPM module? I don't want to loose everything and not be able to save for now on. Just want to be safe rather than sorry. Maybe Macro who create dthe program can help. Thanks... :)
geposted Sat 27 Nov 04 @ 7:31 am
I figured it out. Thanks..... :)
geposted Sat 27 Nov 04 @ 8:52 pm
How ? you fix it ?
(I had no time to test and give you any advise,..working the whole weekend)
geposted Sun 28 Nov 04 @ 2:12 am
This is strange. I right click on a shortcut folder and do a full scan on those changes. Restart the program. It saves.
But...
I organize my files by BPM. I highlight all that have not been scanned. Full scan these. They scan over 3 hours. Many new songs. Assigns the BPM's fine. They are there with the snog lengths. I wait about 10 minutes. Shut down the program. Wait another 10 minutes. Restatr the program and they are gone. ??? I am lost. Any suggestions?
But...
geposted Sun 28 Nov 04 @ 5:48 am
Support.. Any Thoughts? I am thinking of asking for a fresh install of 2.06 and retry it. Please advise.. Still is giving me issues. I rescan for several hours and they disappear...
geposted Mon 29 Nov 04 @ 9:02 pm
I have Vdj 2.00. I make loops and save them as samples. When I close out of Vdj and then start it up again, my loops that I made from songs are not saved anymore as samples. Well they are saved, but whenever I try to load them into my sample list, they won't open up. How can I fix this?
-Dj Digital
-Dj Digital
geposted Tue 30 Nov 04 @ 9:03 pm
Vantine
I would try a re-install of the full 2.06 install.
It seems like there might be something corrupted in your install
geposted Wed 01 Dec 04 @ 2:59 pm
Thanks Norway. I will. You have helped me as you guys always do. Thank you again...
geposted Wed 01 Dec 04 @ 7:37 pm
