The XP10 pitch slider is working in reverse after the latest update.I even tried to map it to the vol. slider and it worked in reverse. The screwed up in the code somewhere since I bought the controller.It worked then but now its backwards.
geposted Sat 27 Nov 04 @ 2:31 am
Not only am I having slider problems my Xp10 jog wheel will not reverse when I turn the jog wheel in reverse . I have two Xp10s and this is the right one .The one on the left turns the correct direction.
geposted Sat 27 Nov 04 @ 3:01 am
The problem with the sliders is only with 2.06 not 2.05. I just did a complete reinstall. The jog wheel problem is all the way back to 2.04 . They need to fix this problem I wont go back to 2.03.
geposted Sat 27 Nov 04 @ 3:33 am
I found the real problem with the slider it was the skin I was using but the problem with the jog wheel is still there.Watch out the person who make the skins can get things wrong and you might think its the update.Yhe 2.06 update did not cause the problem.
geposted Sat 27 Nov 04 @ 4:13 am
