A few of you had mentioned this before, namely, "Andytaylor, Chucknorrisyouwhimps", djmarcel, about the Whorld visualizations. Ypu mentioned you were using them with VDJ. How do you get their files, which are .whp files, to work in VDJ?
Thanx for any help here?
geposted Sun 20 Jan 08 @ 1:32 pm
Hi,
http://whorld.org/download.html
If you downlod "UltraWhorld (Freeframe) Win32 Binary Release", then you can just copy the "Ultrawhorld.dll" into the My Documents/Virtualdj/plugins/video effects folder.
You also have to go to "My Documents" and make a folder called "WhorldFF" and copy all the .whp files you want into that folder. The spelling must be exact and it must be in "My Documents" or else the .whp files won't load.
Then opend virtual dj and the "Ultrawhorld" plugin should be in the video effects folder.
Slider two seems to switch between the different .whp files in that folder. Also, if all you get is just a plain pentagon pattern, then the "WhorldFF" folder isn't in the right location or has been spelt wrong.
All that being said, to be honest they're not that great. I would just use some really cool looking visuals loaded into the clipbank. I'm gonna get this DVD in a few weeks
http://www.mixmash.com/cat_start_mix_n.aspx?productid=673241
and put it as one long file in the clipbank.
Still though, might be worth having a play with.
Hope that helps.
Hope that helps.
geposted Mon 21 Jan 08 @ 12:04 pm
bryantpb
if your after visuals for clipbank send me your email by pm i can help you out there
andy
you should have your link in your email now
Tayla
andy
Tayla
geposted Mon 21 Jan 08 @ 1:05 pm
Thanx Andy. and Tayla I sent you my email now. Thanx to you as well.
Bryant
Bryant
geposted Mon 21 Jan 08 @ 5:53 pm
