I was just wondering if i use my Hercules Mk2 at a party and i want to know if it is possible add a time code turntable, would this work? I would like to do this because at parties i would try to use the hercules to blend the songs while having the turntable to scratch. and use the mk2 as a mixer. I know most djs out there have two turntables. thanks for your help!!
geposted Mon 21 Jan 08 @ 1:03 pm
You can use time-codes with the mk2 , but you are limited to 5 minutes usage of the record for full use of the record you can upgrade to pro at a
discount
discount
geposted Mon 21 Jan 08 @ 2:47 pm
thanks for the help. I made a mistake, i dont have the mk2 i have the hercules dj console mp3 controller. Is there anyway out there that i could hook up a single timecode to my laptop and console after upgrading to the vdj pro? do i need to buy a sound card like the maya 44 usb ??? once again thanks for the help!!! i am so lost
geposted Mon 21 Jan 08 @ 4:32 pm
You'll need to buy the Time Coaded Vinyls.
For 1 turntable you could go through your internal sound card,
But if you want to use 2 turntables you need to buy a sound card like the maya 44.
geposted Mon 21 Jan 08 @ 4:57 pm
where is my internal sound card located? its not in my Hercules dj console is it??
geposted Mon 21 Jan 08 @ 5:08 pm
On a laptop you use the headphone out and the line record in.
On a desk top you use your speakers out and line record in.
geposted Mon 21 Jan 08 @ 5:17 pm
thanks for the help, so when i have the single timecoded Vinyl hooked up to my computer, could i still use the cross faders from my hercules console to control the single timecode?
geposted Mon 21 Jan 08 @ 5:52 pm
any ideas??
geposted Tue 22 Jan 08 @ 10:26 am
