I have a hercules mk1 and i am running numark cue 4.0. and every time i try and turn up the bass it sound somewhat distorted.
does anyone have ideas.
geposted Mon 21 Jan 08 @ 4:41 pm
Do you have all the newest drivers installed?
geposted Mon 21 Jan 08 @ 4:51 pm
It's usally the speakers, turn the volume down and try it and if its ok then the speaker can't handle it that's all. I never turn the bass up on a mixer because I usally run it quit loud and the speakers would pop, you need a Peavey kosmos is you want bass it adds a delay that imatates bass its much cleaner.
geposted Mon 21 Jan 08 @ 5:26 pm
what do i do if it says the skin has a higher resolution than my pc
geposted Mon 21 Jan 08 @ 7:55 pm
do any one know how do i hold the beat on a music with virtual dj 5.0 please need help
geposted Mon 21 Jan 08 @ 8:18 pm
@antone, by turn up the bass, how 'much' do you turn up the bass? and what is the level meter showing?
@marc, i think you need to find a skin which suits your resolution setting. i know some skins will stretch to a larger size to fit, but im not sure the reverse applies
@lionthegreat, try the sync button.
geposted Mon 21 Jan 08 @ 9:47 pm
Press B on ur keyboard to activate Beatlock;) unpress will deactivate it.
geposted Mon 21 Jan 08 @ 11:46 pm
Set ur Pc resolution higher. Or as Paz said, find a skin which suit ur resolution setting.
geposted Tue 22 Jan 08 @ 12:05 am
Try in herc control panel, make the volume 3/4 not all the way;) It should be ok now.
geposted Tue 22 Jan 08 @ 12:06 am
hello fellow Deejays? am currently in the market of buying a new mixer. does anyone one have any suggestions, am thinking either the hercules mk2 with the built in soundcard or the numark total control or one of the behringer mixers. any feedback would be awesome thanks. and keep on spinning!
An'Tone
An'Tone
geposted Wed 23 Jan 08 @ 3:03 pm
