how can you take out the words of a song to mix in another?
geposted Mon 21 Jan 08 @ 7:00 pm
if you mean the vocals, ideally you cannot do this on the fly while mixing. arrange your technique to work around this. there is no perfect solution for removing vocals, but a certain amount can be done in post-production (meaning you cant do this live). do a search around this forum (mix lessons), there are articles about this.
geposted Mon 21 Jan 08 @ 11:22 pm
What I do to get around vocals in order to mix is select either the songs "Hook" or some "empty" beats and loop them. In effect you're creating an artificial "break" in the song so you can mix out or in.
This is particularly helpful to me as a now mobile DJ (former Club DJ). Today I use mostly the Promo Only Radio cuts. That can present a mixing challenge because they're not designed for club mixing. Here's the answer in action. Say you have the radio version of Temperture by Sean Paul. There's no room to mix in w/o stepping on vocals, right? Find the closets to 4 empty beats in the intro then cut down to 2 beats on VDJ. BAAM! you now have a limitless intro break with which to mix into the song. This also works well with radio versions of favorite old club classics. Hope this helps. -Z-
geposted Fri 01 Feb 08 @ 11:01 am
I think this is the most ask question. I think that we should make your "explainatin / how to" thread a sticky. That way people could just read and hopefully understand that it's not an easy process. Also saves you from answering once a week.
geposted Fri 01 Feb 08 @ 1:59 pm
Word. I dug out the post and put it in my blog. When I get some time, I'll expand it more and include actual step by step procedure
geposted Mon 04 Feb 08 @ 12:16 pm
