I am using vdj with cdj800 and maya usb soundcard.I noticed that the sound is still the same as using internal soundcard and does not sound as cd's do.When you try to scratch using the cdj's the sound is more of the same as scratching using a mouse.My friend has once used serato with my cdj and the sound was brilliant, more like vinyl
Do I need to change any settings on the asio config or is that the way its supposed to sound.
geposted Tue 22 Jan 08 @ 10:21 am
