This seem like a hard question to formulate, but when recording a session will it record when in bypass?
So you tell VV to record and you say where you want to put the file.
you start your set with a record and then mix to a song on the PC.
Will it record the record or will it only record what is on the PC?
geposted Tue 22 Jan 08 @ 1:11 pm
that depends on how your gear is setup. there rec function has a config panel which allows you to select the input. you can use the MAster which is the software itself and means that you are recording the software only. however if you use VV in external mixer mode with an external mixer and other stuff, you can set VV to the Line In, which is the soundcard input for recording. this means that whatever gear you have hooked up to the mixer will also get recorded.
geposted Tue 22 Jan 08 @ 8:37 pm
