I guess is possible to do it wit any midi device, isn't it?
geposted Thu 24 Jan 08 @ 12:02 pm
@Ian Knowles
May I use the bcd3000? do I need to map it via midi or with native support it will work?
geposted Fri 25 Jan 08 @ 11:00 am
Yes, I think you will be able to run bcd3000,
But it won't work natively, You do have to map the upfaders to midi.. It is really easy though. just select remote control->general midi->config
Then add and goto video and video_trans_param (move left fader) and OK it and same with right fader and video_trans_param_2
Just waiting on feedback for bugs then i'll submit it for general download.
geposted Sat 26 Jan 08 @ 4:11 am
I already made a general midi mapper for bcd3000,and I also have the midi mixer denon dx5000, I'll add the functions that you say, thanks :)
geposted Tue 29 Jan 08 @ 11:05 am
plugin can now be downloaded btw
http://www.virtualdj.com/forums/84675/General_Discussion/NEW_TRANSITION_-_Available_in_download_section.html
geposted Tue 29 Jan 08 @ 11:20 am
