I don't get it. I had songs there now they are gone. They were from the last job I played. What drives this? Wht is it for? Did I clear it somehow?
geposted Sat 27 Nov 04 @ 3:36 pm
hi
the suggestion box is a smart and dynamic feature.
it "starts" after you have mixed about 5 songs in a row.
the results in the suggestion box will be songs that you usually play around the song you are currently playing, based on your playlists and history
hope that helps :)
hope that helps :)
geposted Mon 29 Nov 04 @ 2:47 pm
