Can you use any type of USB Turntables? or does it have to be a specific type?
geposted Thu 24 Jan 08 @ 4:38 pm
If you want to use timecodes you need a full audio interface like the maya 44 usb or a u46dj or a VV box.
geposted Thu 24 Jan 08 @ 4:58 pm
I think USB turntables are marketed to the general public for those that want to record there vinyl to mp3, (they usually come with some basic ripping software). I think thats it, I doubt they have any kind of pitch control etc for TCV. I may be wrong though...
But yes you'll need an asio soundcard with at least one stereo in pair.
geposted Thu 24 Jan 08 @ 5:04 pm
is it possiable to hook it up to mixers? like the Mk2, or one of the behringers?
and if you need a maya 44 what about laptops? would a DJ IO work??
Thanks dudets?
Thanks dudets?
geposted Thu 24 Jan 08 @ 6:52 pm
No, that is why Skyfxl mentioned soundcards. Using a good quality ASIO soundcard you can accomplish what you are looking for with a regular pair of turntables. Once you have these you can hook them up to mixers. I am not sure..but I believe the MKII is an ASIO soundcard. These sound cards work with all PCs via USB connection.
geposted Thu 24 Jan 08 @ 6:57 pm
Yes the mk2 is an asio soundcards n it werk on mac n pc.
N antone u need to upgrade to pro as ur edition only permit u to 5 minute of usage n limited in features. U can upgrade with a discount. Just go to the link below when u ready to upgrade:)
http://www.virtualdj.com/purchase/discount.html
geposted Fri 25 Jan 08 @ 12:16 am
